Constraint Mates
Constraint mates offer higher pair constraints in the form of distance, coincidence and tangency between two analytical geometries. The geometries could be point, line, sphere, cylinder, cone or a plane. The geometry is defined analytically using bodies and points.
Certain type of constraints may not be applicable based on the geometry involved.
                If the Advanced Joint panel is not currently displayed, select the desired
                    advanced joint by clicking on it in the Model Browser or in
                    the modeling window.
                The Advanced Joint panel is automatically displayed.
                From the Connectivity tab, select the general mating type of the constraints.
                    If Distance is chosen, enter a value in the Distance
                    field.
                Each constraint type further provides various geometric methods to constrain one body with respect to the other body. For example, a general mating constraint type of Distance can be defined between two bodies (Body 1 & Body 2) in order to ensure that a constant distance is maintained between a point on Body 1 with regard to a line on Body 2. In this case, select Point from the Geometry 1 drop-down menu and Line from the Geometry 2 drop-down menu.
 - Specify the geometric methods of constraint for Geometry1 and Geometry 2 using the drop-down menus.
 - Click the Geometry 1 tab and define a body, point, orientation and radius (if applicable) for the type of geometry selected in the Connectivity tab.
                Similarly, define the geometry in the Geometry 2 tab.
                Note: The entity selections which are available for the Geometry1 and Geometry2 tabs are dependent on the constraint and geometry types specified in the Connectivity tab.
Point
- Click the Body collector and select the body constrained by the constraint mate.
 - Click the Point collector and select the point on the body to be constrained.
Sphere
 - Click the Point collector and select the sphere center.
 - Enter a value for the radius of the sphere.
Line
 - Click the first Point collector and select the origin of the line.
                Use the second Point collector to select the point that
                    defines the line from the origin, or, using the drop-down menu to the left of
                    the collector, select Vector and define a vector.
                Note: The marker on Body 1 (I marker) is defined at the line origin and the Z axis of the marker is oriented along the direction defined by the Point|Vector that defines the line. The same applies to the marker on Body 2 (J marker) in the case of the Geometry2 tab.
Cylinder
 - Click the first Point collector and select the origin of the cylinder axis.
 - Use the second Point collector to select the point that defines the axis of the cylinder, or, using the drop-down menu to the left of the collector, select Vector and define a vector.
                Enter a value for the radius of the cylinder.
                Note: The marker on Body 1 (I marker) is defined at the cylinder axis and the Z axis of the marker is oriented along the direction defined by the Point|Vector that defines the axis. The same applies to the marker on Body 2 (J marker) in the case of the Geometry2 tab.
Plane
 - Click the first Point collector and select the origin of the plane axis.
                    defines the axis of the plane, or, using the drop-down menu to the left of the
                Note: The marker on Body 1 (I marker) is defined at the origin of the plane and the Z axis of the marker is oriented along the direction defined by the Point|Vector that defines the plane normal. The same applies to the marker on Body 2 (J marker) in the case of the Geometry2 tab.
Cone
Note: This option is only available for the Geometry2 tab.
            - Click the Body 2 collector and select the second body constrained by the constraint mate.
 - Click the Point collector and select the base point of the cone.
 - Use the second Point collector to select the point that defines the axis of the plane, or, using the drop-down menu to the left of the collector, select Vector and define a vector.
 - Enter a value for the radius of the cone base.
                Enter a value for the height of the cone.
                Note: The marker on Body 2 (J marker) is defined at the base of the cone and the Z axis of the marker is oriented along the direction defined by the point/vector that defines the cone height.
MotionSolve Keywords
The table below summarizes the various combinations of geometry choices along with the keyword TYPE that is written to the Contraint_Mate statement for MotionSolve:
| Constraint Type | Geometry 1 | Geometry 2 | MotionSolve keyword (TYPE) |
| Distance | Point | Point | DIS_POI_POI |
| Sphere | DIS_POI_SPH | ||
| Line | DIS_POI_LIN | ||
| Cylinder | DIS_POI_CYL | ||
| Sphere | Sphere | DIS_SPH_SPH | |
| Line | DIS_SPH_LIN | ||
| Cylinder | DIS_SPH_CYL | ||
| Cone | DIS_SPH_CON | ||
| Plane | DIS_SPH_PLA | ||
| Line | Line | DIS_LIN_LIN | |
| Cylinder | DIS_LIN_CYL | ||
| Plane | DIS_LIN_PLA | ||
| Cylinder | Cylinder | DIS_CYL_CYL | |
| Plane | Cone | DIS_PLA_CON | |
| Cylinder | DIS_PLA_CYL | ||
| Coincident | Point | Cylinder | COI_POI_CYL |
| Sphere | COI_POI_SPH | ||
| Point | COI_POI_POI | ||
| Line | COI_POI_LIN | ||
| Cone | COI_POI_CON | ||
| Line | Cylinder | COI_LIN_CYL | |
| Plane | COI_LIN_PLA | ||
| Line | COI_LIN_LIN | ||
| Tangent | Sphere | Line | TAN_SPH_LIN |
| Cylinder | TAN_SPH_CYL | ||
| Plane | TAN_SPH_PLA | ||
| Cone | TAN_SPH_CON | ||
| Sphere | TAN_SPH_SPH | ||
| Line | Cylinder | TAN_LIN_CYL | |
| Cylinder | Cylinder | TAN_CYL_CYL | |
| Plane | Cylinder | TAN_PLA_CYL | |
| Cone | TAN_PLA_CON |
