RL-GO
With this option the RL-GO parameters are specified.
Parameters:
- Use RL-GO on all surfaces with label
- The label to which the RL-GO should be applied
- (optionally) up to label
- The label up to which the RL-GO should be applied. RL-GO will not be applied to labels outside of the range between this field and the label in the previous field.
- Max no. of ray interactions
- This parameter gives the maximum number of ray-interactions (that is reflection and transmission combined). If for example, the parameter is set to 3, a ray can have 3 reflections, or 2 reflections and a transmission. If left empty, then the maximum number of ray interactions is determined automatically.
- Write ray data to
- *.bof file (default)
- This option exports the rays during the RL-GO solution process to the .bof file for visualisation in POSTFEKO.
- *.ray file
solution process to a .ray file.
This text file can be used for custom post-processing.Note:
- Large .ray files are possible when the MoM and UTD solution have not been decoupled and the MoM part contains a large number of mesh elements.
- For parallel runs the run-time can also increase significantly when exporting ray data.
- Ray contributions (higher order)
- Determines which ray contributions to take into account.
- Ray launching settings
- Specify the settings for the launching of rays.
- Uncoupled with moment method
- This item specifies whether the coupling from the UTD region to the MoM region should be considered. This option should only be used when the UTD and MoM regions do not couple (interact) strongly.
The main advantages of RL-GO are as follows:
- It is suitable for large arbitrarily shaped objects (also curved objects).
- Dielectrics are supported.
- A plane wave source required for the calculation of far field RCS is supported (the UTD has a problem with caustics).
- Multiple reflections can be solved more efficiently than UTD or PO.
When no UT card is used, the following default values apply:
- Max no. of ray interactions: 3
- Write debug information to *.dbg: unchecked
- Export ray data for post-processing: unchecked
- Select ray contributions includes:
- Direct and reflected
- Edge and wedge diffracted rays
- Corner diffraction
