Import STL File
PREFEKO can also import STL — both ASCII and binary — files. STL files supports only triangular patches and these are all imported. Also, since the STL file makes no provision for any labels, label selection is not supported. The scale factor is supported.
An example of an ASCII file
is.
SOLID CATIA STL PRODUCT
FACET NORMAL -4.602166E-01 -1.858978E-01 -8.681260E-01
OUTER LOOP
VERTEX 4.789964E-01 -8.440244E-01 2.878882E-01
VERTEX 4.764872E-01 -8.439470E-01 2.892018E-01
VERTEX 4.783065E-01 -8.414296E-01 2.876983E-01
ENDLOOP
ENDFACET
FACET NORMAL -4.601843E-01 -1.859276E-01 -8.681367E-01
OUTER LOOP
VERTEX 4.761175E-01 -8.425569E-01 2.891001E-01
ENDLOOP
ENDFACET
ENDSOLIDFor the description of binary STL files, please see: www.ennex.com
