Data to STL
You can export Geometries and particles to a CAD file during your simulation.
- Navigate to .
                In the Export Data to STL dialog box, specify the
                    following details:
For Specify Export Data from Particles Select to export data from particles. Geometry Select to export data from Geometries. Both Select to export both Geometries and particles. Export particles using Spheres Select to export Multi-Sphere shapes. Template Select to apply an input CAD template to the particle. Particle Output file (.stl) Click to navigate to the particle output file that generates a name for the exported .stl. Global Particle Scale Select a value from the dropdown list to apply a single value scale to the spheres/templates. This will use the correct particle position but adjust the size of the particles based on the input scale. Timestep Selection Particle Timestep Select the appropriate Time Step for the particle export.  - Click Export to write the .axdt file containing the load data for importing into ANSYS Workbench and the file containing the information on the particle manual selection.
