Analyst Tree-Setup Selections
Analyst Tree-Selections allows you to extract data from a particular area or element in the domain.
Using Setup Selections, you can monitor any element passing through a particular area (known as a 'bin') or track particular elements wherever they move within the domain. You can then display, color, plot, or export data based on these selections and sub-selections.
