Graphs
EDEM Analyst allows you to plot the data collected during your simulation using a number of charts.
Using the toolbar icons, select Analyst and then switch between the 3D Viewer and Create Graph mode.
When you select the Create Graph mode, the Graph tab replaces the standard tabs and the graph is displayed in the Viewer. The Graph pane has four tabs, one for each of the following chart types:
  • Histogram
  • Line
  • Scatter
  • Pie
