ANSYS Workbench Data
You can export pressure and force data on a specific Geometry in text format suitable for ANSYS Workbench import during your simulation.
- Navigate to .
                In the Export Data for ANSYS Workbench dialog box,
                    select Use SI base units or Use EDEM specified
                        units, and then specify the following details:
For Specify Timestep Selection Specify the Start and End Time Steps. Data can be exported for a single Time Step (where Start and End Time Steps are equal or ‘Time Step per file’ is selected) or as time-averaged values (where the Start and the End Time Steps differ and ‘Average to file’ is selected) to minimize the effects of spiking. Force and Pressure Export Geometry Select the Geometry for which data is to be exported. Pressure Select the checkbox and specify the pressure to export the pressure data. Force Select the checkbox and specify the force to export the force data. Orient and transpose to initial CAD position Select the checkbox to perform a transient analysis in ANSYS without the Geometry moving from its initial position. For each Time Step, the force and pressure data is mapped to the initial position. Material Center of Mass Export Select the checkbox to specify a pre-defined particle (manual selection) in order to export the X, Y, and Z co-ordinates of the Center of Mass and total mass for the selection.  - Click Export to write the .axdt file containing the load data for importing into ANSYS Workbench and the file containing the information on the particle manual selection.
