2026
Run analyses and view a variety of results in SimSolid.
Results provide performance insight for the simulation.
Results display for all non-linear analysis types.
View new features for SimSolid 2026.1.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Solve an analysis or design study.
View summary information for all parts in a given Project Tree branch.
You can export deformed shape in ssg/stl format for all parts in a given Project Tree branch.
Show results in a continuous or banded tone contour plot.
Adjust the display attributes for the results plot.
Choose a refinement level for your results plot.
Obtain results at one or more points/faces on the model.
Show a graph of a quantity of interest along a path of a part surface.
Displays a table of resultant bolt and nut forces
Display axial force, shear force and bending moment on the bolts. The output is available along different sections of the bolt that are defined by connections with neighboring parts. Maximum forces/moments across all the sections are also output.
Display a table of loads on a rivet.
Plot a graph of frequencies against load cases.
View the summary of reactions at selected cables/rods.
View a summary of the reactions at selected supports.
View resultant force and moment for selected connections.
View the total reaction force and moments for selected parts.
Display a table of spot weld resultant forces.
Display a table of seam weld resultant forces and stresses.
Review fatigue history for each event at points of interest.
Display a table of spot weld fatigue results in SN fatigue analyses with spot welds present in the design study.
Display a table of seam weld fatigue results in SN fatigue analyses with seam welds present in the design study.
Safety factor plots are used to characterize zones of possible material failure.
View derived result that combines multiple load cases together.
Identify the most significant result out of all selected analyses.
Show a list of parts ranked by movement amplitude.
Show a list of parts ranked by the response.
Control which time or frequency step is displayed for dynamic response data.
View dynamic reaction forces.
Create S-parameters plot.
Create a Campbell diagram.
Create a Damping diagram.
The Bookmark Browser allows you to capture images of your simulation modeling and results, caption the images, and export your gallery as image and/or animation files.
View results for thermal transient or thermal imported linked structural analysis.
View results for squeak and rattle analysis.
Find possible collisions on all deformed parts in assembly for structural and multi-load analysis.
A datum plane can be used either as a clipping plane or to review results.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
This section provides quick responses to typical and frequently asked questions regarding
