Select Loadcase
It shows all available load cases and sub frame results from input results file. The current selected load case and subframe are highlighted in list box
Select the desired load cases to be viewed and click the Display button to view the results.
Note: For Static Analysis, when “Display button is clicked, VonMises stress will be displayed
by default. To view other results, use the result tree in the Assembly tree view in the
Results tab.
