Loading Data
This tool is to define multiple loading types for the
fatigue computation. The loading parameters can be given based on
- OverAall GRMS
- Amplification Factor
- Shock
For each loading type, the cycles to failure, lifetime, and used life of the selected component will be calculated. Additionally, the overall combined life, used life, and lifetime across all loading types will also be computed.
