Imposed Current Coil - 2D Solutions
Introduction
The Imposed Current Coil allows you to define a body / bodies as a coil and enter the associated physical data.
Note: See Coils modeling for more explanations
about the different possibilities of modelling of coils.
Dialog Box
Prerequisite: The bodies to define as Imposed Current Coils must be meshed.
- Select bodies: Select one or several bodies to define as a coil
- Number of turns: Enter the number of turns of the coil
- Current value: Enter the current value
- Conductor connection: is used if
symmetry or periodicity entities are existing. This input allows to define
the symmetric or periodic coils as in Series or in
Parallel. That means that if a current
"I" is flowing into the represented coil, then
each symmetric or periodic coil will have:
- in series: I
- in parallel: I divided by the total number of
coils in the complete deviceNote: for example, if the device has one symmetry, the current on the represented coil and in the symmetric coil will be I/2. If the device has a periodicity with a total of 6 portions, the current on each portion coil will be I/6.
- Current orientation: allows to define the current
orientation into the coil body. There are two possibilities:
- Positive
- Negative
