Temperature
Analysis > Magnetostatic Loads > Temperature
The Temperature allows the user to specify the working temperature of the bodies in their electromagnetic analysis.
Warning: Working temperature can only be considered if the bodies are assigned to a temperature dependent material, by describing the thermal properties. For more information, please see Material - Thermal properties.
