Composites Library
The Composites library contains operators that calculate multiple composite failure theories.
It is supported for the following set up:
- Solver profiles: OptiStruct and Nastran
- Applicable only for 2D shell elements with property definition as per Zone Based Modelling with PCOMPG and/or PCOMP
- Output Format: Composite Stress in Tensor Format (for example, *.op2)
