Default Arguments
When an operator is inserted into the expression, the defaulted argument list is
hidden:
In the example above, a failure theory operator is inserted, however since the Hide Default Arguments is checked, only the parameters that do not have a default value are shown. This mode effects how the operator will be inserted into the expression text, and will not change any existing text. An expression can consist of Operators that have default values shown, in addition to ones that have default values hidden. Additional arguments can be added to the inserted Operator, by simply adding a comma-separated list of parameters.
The Operator above will appear as follows with the Hide Default Arguments option
deactivated:
