Known Limitations
Below is a list of the current known limitations for Result Math:
  • OptiStruct max strain failure theory output does not match the Composites library max strain failure theory output. There is an issue with the OptiStruct computation.
  • Tensor transformations from local to global are incomplete, and do not support material and ply-based tensors.
  • Tensor transformations from local to global for nodal tensors are not implemented yet.
  • In HyperView, if a part-bound contour is applied after a node or element bound contour, the color tables in HyperView is not cleared and will display the nodal or elemental colors.
  • It is not possible to query, measure, or reference in a note a part-bound value.
