Translate, Rotate, and Scale an Object Using the Position Tab
From the Add Object panel, select an object from the Add Objects list.
Tip: You can also click on the object in the modeling window.
- Click Apply.
From the Position tab:
Option Description Origin Change the X, Y, and Z settings to translate the object within its coordinate system. Orientation Change the RZ, RX, or RZ settings to rotate the object using Euler angles. Scale Change the SX, SY, and SZ settings to scale the object three-dimensionally. -
Click Apply.
The selections to the object are applied and displayed in the modeling window.
