Rotate a Graphical Object Using the Transform Tab
From the Add Object panel, select an object from the Add Objects list.
Tip: You can also click on the object in the modeling window.
- Click the Transform tab.
- Under Rotate, enter the rotational delta values for RX, RY, or RZ.
- Select an axis of rotation (RX, RY, or RZ), if necessary.
- Press the + or - buttons to rotate the object.
