Translate a Graphical Object Using the Transform Tab
From the Add Object panel, select an object from the Add Objects list.
Tip: You can also click on the object in the modeling window.
- Click the Transform tab.
- Under Translate, enter offset values for X, Y, and Z.
- Activate the X, Y, and Z check boxes to indicate the desired axes of translation (if necessary).
- Press the + or - buttons to translate the object along the offset vector.
