Import
The Tools menu Import option allows you to access sub-menu options and dialogs for plot styles, sets, and views.
Import Plot Styles
From the Tools menu, select
. The Import Styles dialog is displayed.
- Use the Look in drop-down menu to browse to the desired .xml file.
Click on the desired file and click Open.
A message log window will appear confirming that the file has been imported.
- Click Close to exit the message log window.
Import Sets
. You are automatically taken to the Set panel, and the Import Sets dialog is displayed.Note: You can also access the Import Sets dialog by clicking Import in the Set panel.
From the Select format drop-down menu, select a file type.
- HyperView group definition file
- Animator3 session file
- LSPost group file
- Patran session file
- Under File name, click the open folder icon and browse to the desired file which contains defined sets (groups).
- Click Open.
Click OK to close the dialog.
- HyperView extracts all defined sets (groups) in the selected session file.
- The HyperView groups, Animator3 groups, or LSPost groups are listed in the Groups list.
- By default, the visibility of each imported group is turned off.
Import Views
. The Import Views dialog is displayed.
- Use the Look in drop-down menu to browse to the desired .txt file.
- Close Close to exit the message log window.
