How to Use FIALA Tire
- Add an AutoTire in a MotionView session.
- Resolve the attachments.
- Select the Fiala Tire property file.
Select the Road property file.
The FIALA model with a single point contact method should only be used with flat road. If the tire property file contains a [CONTACT_COEFFICIENTS] block, then the following road surfaces can be used:
- Flat
- 2D and 3D Cleat
- CRG
- 3D Spline with single thread
