Contact Patch Parameter Extraction
What is Altair's Simplified Durability Tire?
The Simplified Durability Tire model is a combination of the FIALA tire model and the 3D enveloping contact method. The 3D contact method captures the road surface using a series of parallel cams. The following characteristics of the road surface are captured:
  • Effective road height variation
  • Effective slope variation
  • Camber change
Based on the above variations, the forces are calculated using the FIALA algorithm. The 3D contact method allows you to predict the enveloping behavior of tire when rolling over an uneven surface.
Contact Patch Parameter Extraction from Testing
The following parameters are required to use the 3D enveloping contact with FIALA tire:
PA1 Coefficient of square root term in contact length equation
PA2 Coefficient of linear term in contact length equation
PAE Half of ellipsoid length
PBE Half of ellipsoid height
PCE Order of ellipsoid
PLS Scaling of distance between front and rear ellipsoid
ROAD_INCREMENT Mesh Size for ellipsoid
N_WIDTH Number of cams along contact width
N_LENGTH Number of cams along contact length
PA1, PA2 show the variation of the contact patch length. The size of the contact patch increases with an increasing vertical load. The dimensions of the contact patch can be obtained by pressing a tire on carbon paper or by using ink.
Figure 2. Tire contact patch dimension 205/65 R16 at 4.7 KN and 2.5 bar
Contact Length Equation:
a= r 0 PA2* F Z / C Z r 0 + PA1 F Z / C Z r 0  ≈  r 0 PA2*ρ/ r 0 + PA1 ρ/ r 0 MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGHbGaeyypa0JaamOCa8aadaWgaaWcbaWdbiaaicdaa8aabeaa k8qadaqadaWdaeaapeGaamiuaiaadgeacaaIYaGaaiOkaiaadAeapa WaaSbaaSqaa8qacaWGAbaapaqabaGcpeGaai4laiaadoeapaWaaSba aSqaa8qacaWGAbaapaqabaGcpeGaamOCa8aadaWgaaWcbaWdbiaaic daa8aabeaak8qacqGHRaWkcaGGGcGaamiuaiaadgeacaaIXaWaaOaa a8aabaWdbiaadAeapaWaaSbaaSqaa8qacaWGAbaapaqabaGcpeGaai 4laiaadoeapaWaaSbaaSqaa8qacaWGAbaapaqabaGcpeGaamOCa8aa daWgaaWcbaWdbiaaicdaa8aabeaaa8qabeaaaOGaayjkaiaawMcaai aacckacqGHijYUcaGGGcGaamOCa8aadaWgaaWcbaWdbiaaicdaa8aa beaak8qadaqadaWdaeaapeGaamiuaiaadgeacaaIYaGaaiOkaiabeg 8aYjaac+cacaWGYbWdamaaBaaaleaapeGaaGimaaWdaeqaaOWdbiab gUcaRiaacckacaWGqbGaamyqaiaaigdadaGcaaWdaeaapeGaeqyWdi Naai4laiaadkhapaWaaSbaaSqaa8qacaaIWaaapaqabaaapeqabaaa kiaawIcacaGLPaaaaaa@6A09@
Contact Width Equation:
b=w/2 MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGIbGaeyypa0Jaam4Daiaac+cacaaIYaaaaa@3A70@
Parameters Details
a MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGHbaaaa@36FE@ Half of the contact patch length
b MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGIbaaaa@36FF@ Half of the contact patch width
r 0 MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGYbWdamaaBaaaleaapeGaaGimaaWdaeqaaaaa@3823@ Unloaded tire radius
ρ MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqaHbpGCaaa@37D8@ Tire deflection
w MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWG3baaaa@3714@ Width of the tire
C Z MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGdbWdamaaBaaaleaapeGaamOwaaWdaeqaaaaa@3819@ Radial stiffness of tire
Using the curve of contact patch dimensions versus vertical load or vertical deflection you can obtain PA1, PA2.
Important: The test matrix should have at least three different vertical loads and constant pressure, 0 camber.
Ellipse dimension: When a tire starts rolling over an obstacle, the shape of the tire circumference forms an elliptical contour. This is the basis of the elliptical cam contact model. A set of images of a tire rolling over an obstacle can be post-processed to extract the ellipse dimensions that are used in simplified durability tire. The image below presents the idea of extracting ellipse dimensions from test images:
Figure 3.
The equation for the shape of cam can be written as:
PCE is the order of these ellipsoids and can be obtained using curve fitting.
For PLS a standard value of 0.8 is used.
Figure 4. Obstacle enveloping using elliptical cams
Tire parameter extraction from testing
For calculating the vertical load, the following parameters are needed:
  • Radial stiffness
  • Radial damping
These parameters can be obtained by simply pressing the tire and measuring the tire deflection. The damping can be obtained by measuring the response of tire to an impulse excitation.
For longitudinal force, the following parameters are needed:
  • Longitudinal slip stiffness
  • Relaxation length in longitudinal direction
  • Coefficient of friction between tire and road
For lateral force, the following parameters are needed:
  • Cornering stiffness
  • Relaxation length in lateral direction
