COSIN/io 2D Road Type: ramp
Name of input variable | Unit | Meaning |
height | mm | Height of ramp. |
start | m | Start of ramp (travel distance). |
slope | - | Slope of ramp; 1 means 45deg. |
View new features for Altair HyperWorks 2023.1.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
To specify and evaluate road excitation, COSIN/road uses one central subroutine evrmr (COSIN environmental models: road main routine).
If COSIN/road detects the road file in COSIN/io format, it first tries to read certain information common to all road types within this format (see Data Common to all COSIN/io Style Road Types).
If COSIN/road recognizes the road data file is in TeimOrbit format (typically, the file name extension is rdf), it branches into the respective reading and evaluation routines.
If the road data file is in COSIN/io format, but does not contain the data block $road_type, it is interpreted as a COSIN road track file.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
