Save and Reload Models with CDTire
CDTire supports saving and reloading when included in a MotionSolve model. Upon saving a model using the <Save/> command, CDTire saves its states into an encrypted file with the extension .cdr. For more information on saving and reloading MotionSolve models, please refer to the MotionSolve Reference Guide.
When the model is reloaded using the <Load_Model/> command, CDTire’s saved states are also reloaded during the initialization. The simulation then proceeds.
Note: While CDTires can be used in models that are saved and reloaded, it is recommended not to save a model with CDTire immediately after a Static simulation. A short duration of Transient simulation is required for the model to fully initialize the tires’ states, before a <Save/> command can successfully save them.
