Modify a Particle Shape
You can modify a particle shape by changing the values in the table.
                Select the particle from Shape Library dialog box and
                    then select Modify Shape.
- Set the radius, X, Y, Z position and sphere separation (in the X and Y axes) of each shape in the Adjust Settings dialog box.
