Add Sphero-Cylinder Particles
You can define a Sphero-Cylinder particle using the length and radius, where the length is the total length of the particle including the rounded ends.
To add a Sphero-Cylinder particle:
Right-click Bulk Material, select Add Particle and then and select Add Sphero-Cylinder.
Alternatively, click the  icon.
A new particle is defined in the Creator Tree.
Note: The length is given by the total length of the particle including the rounded ends.
