Import Custom Particle Shapes
EDEM allows you to create and define flexible fiber/materials.
- Select Import Custom Particle Shape to select a CAD Geometry to import as a particle shape.
- Select Size Distribution to modify the particle size by changing the size distribution.
Note: When you select Calculate Properties, the Geometries
can only be convex and will be centered based on their center of mass. For more
information on how to calculate particle properties, see Calculate Particle Properties.
