Solve
Steps
In the Solution Browser (second tab), right-click on Results and choose Update.
In the Solution Browser, the solving process is in progress, you can see that Results is now preceded by a yellow light.
Note:
- You can see the solver log by right-clicking on Results and selecting the contextual menu View Solver Log.
- You can stop the solving by right-clicking on Results and selecting the contextual menu Kill Solving.
→ Once the solving process is completed, the light turns green.
→ The graphic window is updated with the color shade results with its options on the top left:
Storage of files
During the solving all the Flux files are stored in a path. This path can be defined
through the contextual menu of Solutions in the
Solution Browser:
- Set to Scratch Folder takes the Scratch folder specified
in the Preferences dialog box (accessible in the
File menu) in the category , in the field Scratch directory as the
path for all the simulations.
By default it is C:/Users/...
The files are stored in the solved solution name folder inside the SolverRun folder.
- Set to Database Folder takes the same location as the active *.slb database. The files are stored in the solved solution name folder inside a folder having the *.slb name.
- Set to Selected Folder allows to choose the path where
all simulations files will be stored.
The files are stored in the solved solution name folder.
Note: The first line beginning with Current
: indicates the current selected path. In this image it is
Database Folder.
Note: At the end of solving, the command Open Results
Folder in Results contextual menu allows to
open an explorer window at the location where all the files were saved.
