Infinite Region - 2D Solutions
This tool is to define the study region in space for the magnetic analysis. User can see the preview of the infinite region in window.
For CAD based solution:
- Infinite region will be stored as region data.
- On mesh / update, Region data will be converted to CAD bodies.
- Modifying the infinite region data, Delete the created CAD bodies if available.
- The radius collected is the inner radius, The outer radius will be computed internally.
For Mesh based solution:
- The mesh for the infinite region will be created within Flux.
Note:
- Currently only disc type can be defined in SimLab.
