2026
Create, organize, and manage parts and subsystems.
The pdmsyscfg.xml file defines system behaviors for Altair HyperWorks PLM connectors. The pdmsyscfg.xml file supports background processes, file-type recognition, revision checks, dataset mapping, encoding schemes, and more.
Key configuration settings for PTC™ Windchill connector users.
View new features for Altair HyperWorks 2026.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Key configuration settings for Siemens Teamcenter™ connector users.
The <QueryContext> section defines the saved queries available in the Inspire or HyperWorks products UI for retrieving Windchill objects such as CAD documents and parts.
<QueryContext>
Key configuration settings for OpenPDM connector users.
Set up the UDM to PDM mapping files: plmxml_udm_config.xml, wc_udm_config.xml, openpdm_udm_config.xml, and ap242_udm_xml.
Configure and register Altair Webjects for use with Windchill.
Learn how to update Java security certificates for HyperMesh using the keytool utility that comes bundled with HyperMesh's Java Runtime Environment (JRE).
Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
Use the Organize tool to move or copy entities into their proper destinations.
Automatically group selected parts into part sets based on comparison method and criteria selected.
Set up and use machine learning (ML) models to automatically classify parts under user-defined labels and into part sets.
Use the Renumber tool to review and organize the IDs of model entities.
Change the order of named entities in database.
Manage the IDs for the entities that you create, and define ID ranges for the entities in each Include file in order to avoid ID duplication across files.
Use the Reps tool to perform representation operations for parts and subsystems.
Scenarios are a mechanism to apply controls to engineering entities.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Compare and update a current HyperMesh session with an incoming model and generate comparison results.
Use the Overlay tool to superimpose a second representation as overlay onto the current (session's) representation and inspect their differences.
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction, transforming results, defining material orientation, and many other operations.
Define vectors in 3D space.
Define physical and mathematical characteristics of parts.
Import materials directly from the Altair Material Data Center (AMDC).
Automatically distribute masses on nodes, properties, or parts to match user-defined target mass and center of gravity (COG).
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
Use the curve editor to create and plot XY curves.
The Abaqus solver offers the flexibility of modeling rigids as surfaces using primitive geometry.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
