UDMToAP242ContentDefinitions Configuration
The <UDMToAP242ContentDefinitions> section defines how Altair UDM content types are mapped to AP242 categories and formats
during XML transformation. This ensures compatibility when exporting UDM content into
AP242-compliant XML structures.
Purpose
The purpose of the
<UDMToAP242ContentDefinitions> section is to:- Convert UDM content definitions into standardized AP242 file types for downstream interoperability.
- Ensure correct categorization of representation and file formats when transitioning to AP242.
Structure Overview
Each
<UDMToAP242ContentDefinition> block maps a single UDM
representation and file type to its corresponding AP242 values.| Element | Description |
UDMRepresentationCDef |
UDM content definition for the representation object |
UDMFileCDef |
UDM content definition for the file object |
UDMFileType |
Logical file type within the UDM context (for example, HyperMesh, CATIA V5) |
UDMFileExtension |
Expected file extension used in the UDM model (for example, .hm, .CATProduct) |
AP242FileType |
Standard AP242 representation type (for example, geometry, FE data) |
AP242FormatProperty |
Format identifier used in the AP242 representation.format property |
Example Configuration
| UDM Format | Maps to AP242 | Purpose |
| HyperMesh (.hm) | FE data, HYPERMESH | FEA mesh data |
| CATIA V5 (.CATProduct) | geometry, CATIA V5 | CAD geometry assembly |
Best Practices
- Ensure that each UDM file type and extension matches the actual exported data.
- Use AP242-standard terminology for AP242FileType and AP242FormatProperty to remain compliant.
- Validate your mappings against your target system’s import capabilities for AP242 files.
