Create, Review, and Edit MPC Equations
Create MPCs
MPCs are used to create a simple linear equation that relates the displacements of the included nodes and degrees of freedom. MPCs are activated in the case control similar to other boundary conditions.
From the Analyze ribbon, click the tool.
Note: In Abaqus, use the Equations tool instead.The guide bar shows the active card image. In ANSYS, you can choose between several different cards.
Select the independent node(s).
At least one independent node is required.
Select a dependent node.
The MPC is automatically created upon selecting the dependent node.
A degree of freedom that is specified as dependent may not be specified as dependent for any other entity in the model (for example, RBE, MPC, SPC).
- Optional:
Click
and
on the microdialog to adjust
the degrees of freedom of the dependent and independent nodes to be included in
the MPC.
Only one DOF is allowed for the dependent node.
- Optional:
Click
on the microdialog to specify a uniform weighting factor or
automatically calculate the weighting factors of the independent nodes based on
their respective distance from the dependent node.
- Optional:
Click
on the microdialog to enter node-based editing mode.
- Optional:
Click
on the microdialog to reposition the dependent node using the
Move tool.
If the dependent node is attached to other elements, a new node will be created and moved to the new location.
On the guide bar, click
to create another MPC or click
to exit the tool.
Review and Edit MPCs
To open the MPC tool in edit mode, do one of the following from idle:
- Double-click on an MPC.
- Select an MPC, then select Edit from the right-click menu.
- Select an MPC, then access the tool via the ribbon icon.
- Utilize any of the actions noted above to review or modify the MPC connectivity, DOF, and/or independent node location.
to exit the tool.
- Refer to the entity status icon on the guide bar for status and feedback. Clicking the icon will fit the view to the current MPC.
- Changes made in the MPC tool are automatically committed to the database. If a change is made that invalidates the MPC (for example, clearing the independent node selection), the MPC will turn grey and the database will not be updated until the MPC is made valid again. The entity status icon and error flags on the selectors help identify required inputs.
- Hold Ctrl (add) or Shift (remove) in to select individual nodes in quick succession. The MPC will be updated upon releasing Ctrl/Shift.
