Add Mapping for Missing or Custom Dataset and Named Reference Types
If your Teamcenter business model includes custom dataset types such as ProEDataset_asm or ProEDataset_prt for Creo assembly and part files, you’ll need to update your configuration to ensure proper mapping and downstream compatibility with HyperMesh.
Update the
<FailingOrder>section by adding the ProE keyword to the list.This is a reserved type recognized by the HyperMesh API and enables the correct association with your Creo files. For the full list of supported values, refer to Supported UDMElementType Values.<FailingOrder> <Value>ProE</Value> <Value>CATIA V5</Value> <Value>JT</Value> <Value>Unigraphics</Value> </FailingOrder> -
Add custom dataset mapping to
<PLMXMLElementToUDMContentDefinitions>by inserting the following blocks to define how your custom datasets should be interpreted by HyperMesh.<PLMXMLElementToUDMContentDefinition> <PLMXMLElement>DataSet</PLMXMLElement> <PLMXMLElementType>ProEDataset_asm</PLMXMLElementType> <UDMContentDefinitionType>UDMRepPartCad</UDMContentDefinitionType> <UDMIsPrototype/> <UDMElementType/> <UDMBindingClass>com.altair.hwec.udm.base.RepresentationPartCType</UDMBindingClass> </PLMXMLElementToUDMContentDefinition><PLMXMLElementToUDMContentDefinition> <PLMXMLElement>DataSet</PLMXMLElement> <PLMXMLElementType>ProEDataset_prt</PLMXMLElementType> <UDMContentDefinitionType>UDMRepPartCad</UDMContentDefinitionType> <UDMIsPrototype/> <UDMElementType/> <UDMBindingClass>com.altair.hwec.udm.base.RepresentationPartCType</UDMBindingClass> </PLMXMLElementToUDMContentDefinition>Note: If you're defining a CAE dataset, replaceUDMRepPartCadwithUDMRepPartMesh. -
If your datasets reference external files (.prt,
.asm, and so on), include the following named reference
mappings:
<PLMXMLElementToUDMContentDefinition> <PLMXMLElement>ExternalFile</PLMXMLElement> <PLMXMLElementType>prt</PLMXMLElementType> <UDMContentDefinitionType>UDMDSFileCAD</UDMContentDefinitionType> <UDMElementType>ProE</UDMElementType> <UDMBindingClass>com.altair.hwec.udm.base.DataSourceFileCType</UDMBindingClass> </PLMXMLElementToUDMContentDefinition><PLMXMLElementToUDMContentDefinition> <PLMXMLElement>ExternalFile</PLMXMLElement> <PLMXMLElementType>asm</PLMXMLElementType> <UDMContentDefinitionType>UDMDSFileCAD</UDMContentDefinitionType> <UDMElementType>ProE</UDMElementType> <UDMBindingClass>com.altair.hwec.udm.base.DataSourceFileCType</UDMBindingClass> </PLMXMLElementToUDMContentDefinition>Note: UseUDMDSFileCADfor CAD content andUDMDSFileMeshfor CAE/mesh data. Match this with theUDMRepPartCadorUDMRepPartMeshtypes you’ve defined above.- Supported
UDMELEMENTTypeValues -
- For
UDMDSFileCAD - Acis, Aveva, CATIA, CATIA V4, CATIA V5, CATIA V6, DXF, ECAD, FEMAP, FORAN, HyperMesh, HyperForm, HMAscii, IFC, Iges, Inspire, Intergraph, Inventor, JT, Parasolid, PDGS, Pdgs, ProE, Pro/E, Rhino, SolidWorks, Step, STEP AP242 XML, STL, Tribon, Unigraphics, VDAFS.
- For
UDMDSFileMesh - Abaqus, Ansys, Ansa, HMAscii, HyperForm, HyperMesh, Ls-Dyna, Ls-Dyna Seq, Moldflow, Nastran, OptiStruct, Pamcrash, Pamcrash 2G, Permas, Radioss Block, Radioss Bulk, Stl.
- For
- Supported
After editing the XML file, validate the XML file structure.
