Unmask Selected Entities
- From the Mask panel, set the input collector to the entity type you want to unmask.
- Create an entity selection set using the input collector or by picking entities from the screen.
- Under Action, select Unmask.
Click Unmask Selected.
The selected entities are unmasked.
- Set the input collector to the entity type you want to unmask.
- Use the quick window selection to select a set of entities.
The entities inside the window are unmasked.
