Mask Selected Entities
- From the Mask panel, set the input collector to the entity type you want to mask.
- Create an entity selection set using the input collector or by picking entities from the screen.
- Under Action, select Mask.
Click Mask Selected.
The selected entities are masked.
- Set the input collector to the entity type you want to mask.
- Use the quick window selection to select a set of entities.
The entities inside the window are masked.
