ElementAxisVector
Transforms a vector relative to the elemental system to the global system.
- elems
 - An element entity table.
 - coords
 - A coordinate vector value table.
 - vector
 - A vector relative to the elemental system.
 - elemSysMethod
 - The element system method for the model. Valid values are "Bisect" (default value) or "Midpoint" (to be used for all Radioss models).
Outputs
- answer
 - A elemental vector value table.
- All vectors in coords must be relative to the global system.
 - The vector string is a space-separated list of three scalar values.
 - elemSysMethod is only applicable for Element-bound vectors and is specific to quadrilateral elements only.
ElementAxisVector(elems,coords,vector,elemSysMethod)XML Example
<call name="ElementAxisVector" vector="1 0 0"
coords="coord_tab" elems="elem_tab"
answer="ans_tab" />
