BCSetToElem
Assigns set values to elements.
src
A set value table.
sets
A set entity table.
pool_name
Name of the element pool in the set.
Outputs
answer
An elemental value table.
  • If src is a vector or tensor table, it should be transformed to the global coordinate system.
  • Aggregation modes are not applicable for this operation.
  • The Expression Builder will auto-fill pool_name with @current_pool (assigned by the application).
BCSetToElem(src,sets)
XML Example
<call name="BCSetToElem" src="src_tab" sets="set_tab"
pool_name="shell" answer="ans_tab" />
