The ability to visualize tires deforming is important during
the post processing of a simulation that used FTIRE. This can be done in HyperView by
including the use of Grasub in the Post_Graphic xml entity (as shown below).
The 10.0-SA-110 and later versions of the mdllib contain this by default inside the
Tire system definition; however it is default set to 'off' (this is because usage of this
subroutine costs CPU time, and its main value is to visualize tire deformation related to
FTire).
To make this active simply right-click on the Grasub for Ftire
Template item in the Model Browser and select
Activate from the context menu.
xml syntax for
MotionSolve
<!-- GRASUB FOR FTIRE -->
<Post_Graphic
id = "4000001"
type = "UserGra"
ref_marker_id = ""
usrsub_param_string = "USER(1, 2, , 40, 72)"
usrsub_dll_name = "[path to your install]/hwsolvers/bin/win32/mbdtire.dll"
usrsub_fnc_name = "tiregra"
<Post_Graphic
id = "4000002"
type = "UserGra"
ref_marker_id = ""
<Post_Graphic
id = "4000003"
type = "UserGra"
ref_marker_id = ""
<Post_Graphic
id = "4000004"
type = "UserGra"
ref_marker_id = ""
The
parameters are described below:
Par[1] = tire GFORCE id
Par[2] = reference frame for
output mesh (1 - output expressed in inertial frame, 2 - output expressed in rim fixed
frame, 3 - output expressed in tydex-C frame)
Par[3] = uMax number of slices along the
lateral direction (from side to side of the tire…)
Par[4] = vMax number of subdivision
(or wedges) along the circumference
