Limited Slip Differential (LSD)
Limited Slip Differential (LSD) is a type of differential that allows the individual drive shafts (left/right) to rotate at different speeds but provides an option to limit the difference between the two. This is accomplished by providing a mechanism that resists the speed differential between the shafts. This could be a clutch or viscous coupling-based design.
LSD in MotionView Vehicle Libraries
In MotionView’s Car/Small truck and Heavy truck library, a viscous coupling is used between the left-right drive shafts to model the slip limit.
LSD can be included while building a vehicle model using the assembly wizard. The selection is available under Front diff lock and/or Rear diff lock on the “Additional Systems for Full Vehicle with driver model” page:
Figure 1. Differential lock selection for a 4wd configuration
Once the model is built, the diff locks system is created under the respective axle’s drive System:
Figure 2. Differential lock within the Drive system
LSD Model
The limited slip differential is modeled using a simple rotational force/torque. The torque is an expression that is a function of:
  • A damping coefficient (DAMP_COEFF)
  • Delta of rotational speeds of the shafts (OMEGA_DIFFERENCE)
  • Desired allowable difference between shafts’ rotational speeds (ALLOWABLE_SPEED_DIFFERENCE)
  • A numerical switch (1, 0) that is used to switch On/Off the locking torque (LOCK_STATE)
T = LOCK_STATE * DAMPING_COEFF * (| OMEGA_LEFT – OMEGA_RIGHT |)
To allow for a smooth transition while engaging the lock, a STEP() function is used in the above expression:
T = LOCK_STATE * STEP( OMEGA_DIFFERENCE, ALLOWABLE_SPEED_DIFFERENCE, ALLOWABLE_SPEED_DIFFERENCE + 0.1, DAMP_COEFF * OMEGA_DIFFERENCE )
The torque acts between the Left and Right halves of the drive shaft.
Interface
For easy manipulation of the diff lock parameters, a Form has been provided in the system which can be used to edit the values. Outputs are also available for plotting during result post-processing.
Figure 3. Interface for editing parameters and Outputs
