Deformable Surface
  1. If the Graphics panel is not currently displayed, select the desired graphic by clicking on it in the Model Browser or in the modeling window.
    The Graphics panel is automatically displayed.
  2. From the Connectivity tab, click the DeformableSurface collector and select a deformable surface from the modeling window, or double click the DeformableSurface collector to open the Model Tree (from which the desired surface can be selected).
    The graphic will consist of a mesh utilizing all of the markers and points from the deformable surface.
  3. Click the Properties tab.
  4. Enter the number of segments in the U direction (row) for the deformable surface.
  5. Enter the number of segments in the V direction (column) for the deformable surface.
