Deformable Road
A DeformableRoad type graphic can be used in conjunction with a tire and Soft Soil Modeling road in vehicle models.
To edit this graphic:
Select the desired graphic by clicking on it in the Model Browser or in the modeling window.
The Graphics panel is automatically displayed.
- Use the icon next to Graphic source to browse and select a graphic file.
- Click the Marker collector and select the marker that you want to use as a reference marker to locate the graphic. By default, the Global Frame is set as the reference marker.
