FreqBushing - Entity
The Altair Bushing Model, also known as a FreqBushing entity in MotionView, is a sophisticated model that you can use to simulate the behavior of bushings in vehicle dynamics, durability and NVH simulations.
Connect a FreqBushing from the Entity Editor
Connections define the two connecting bodies, the point where the forces act, and the marker that defines the bushing orientation. Bodies, markers, and points can be selected either graphically or through the Model Browser.
From the Selector tab, select the first body to connect.
The I marker of the Force_field statement in the solver deck lies on Body 1, is located at Point 1, and has the orientation of Marker.
- Click Body 1 and select a body from the modeling window.
- Double click Body 1 and select the required body from the dialog.
Similarly, select the second body to connect by clicking the
Body 2 input collector.
The J marker of the Force_field statement in the solver deck lies on Body, is located at Point 1, and has the orientation of Marker.
Select a point to locate the bushing. The point defines the location where the
bushing forces act. The I marker and the J (floating) marker of the
Force_field statement are at Point 1.
- Click Point 1 and select a point from the modeling window.
- Double click Point 1 and select the required point from the dialog.
Select a marker to orient the bushing in space.
- Click Marker and select a marker from the modeling window.
- Double click Marker and select the required marker from the dialog.
All three axes of the bushing are along the axes of the respective axes of the Marker (X-X,Y-Y,Z-Z).Tip: Click Edit File to edit and save the bushing property file.
TeimOrbit FreqBushing File
A sample TeimOrbit FreqBushing text file is shown below.
$-----------------------------------------------------------HEADER
[HEADER]
FILE_TYPE = 'gbs'
FILE_VERSION = '1.1'
FILE_FORMAT = 'ASCII'
$------------------------------------------------------------UNITS
[UNITS]
TIME = 'Sec'
LENGTH = 'MM'
FORCE = 'Newton'
ANGLE = 'Degree'
MASS = 'Kg'
$------------------------------------------------------------GLOBAL
[GLOBAL]
EPSILON = 1.0000000000000001E-005
COUPLING = 'Uncoupled'
$------------------------------------------------------------DIRECTIONS
[DIRECTIONS]
(ACTIVITY)
{ Formulation FX FY FZ TX TY TZ }
'SPLINE_STIFFNESS' 1 0 0 0 0 0
'CUBIC_STIFFNESS' 0 0 0 0 0 0
'CONSTANT_STIFFNESS' 0 1 1 1 1 1
'CONSTANT_DAMPING' 0 1 1 1 1 1
'RUBBER_DAMPING' 1 0 0 0 0 0
'HYDROMOUNT_DAMPING' 0 0 0 0 0 0
$----------------------------------------------------SPLINE_STIFFNESS_FX
[SPLINE_STIFFNESS_FX]
(SPLINE_DATA)
{ disp force}
-2.10000 -10120.00000
-2.05000 -9120.00000
-2.00000 -8240.00000
-1.90000 -7060.00000
-1.80000 -5256.96000
-1.70000 -4376.96000
-1.65000 -3611.56000
-1.50000 -3169.57000
-1.45000 -2464.31000
-1.35000 -2070.31000
-1.15000 -1967.72000
-1.10000 -1656.96000
-1.00000 -1151.96000
0.00000 0.00000
1.00000 1070.00000
1.10000 1441.00000
1.70000 1730.00000
2.00000 1868.50000
2.50000 2493.04000
2.90000 2803.04000
3.00000 3163.04000
3.15000 3323.04000
3.40000 3483.04000
3.65000 3593.04000
3.80000 3623.04000
3.90000 4443.04000
4.05000 5103.04000
4.15000 5300.00000
4.40000 5800.00000
$------------------------------------------------------RUBBER_DAMPING_FX
[RUBBER_DAMPING_FX]
NPRELOADS = 1
(PRELOAD_1)
PRELOAD = 0.0000000000000000E+000
R = 1.0984344869354972E+000
K0 = 2.1291366586210524E+003
K1 = 2.0003149481217424E+004
K2 = 5.7832750782252319E+001
C0 = 3.7031090214294602E+002
C1 = 3.3917669230363902E+002
C2 = 5.3050041580213869E-001
P0 = 5.0820696402844403E+000
P1 = -4.4259813439671127E+000
P2 = 1.3941895515214624E-002
Q0 = 1.6145231637586410E+000
Q1 = -2.1513678904349827E+000
Q2 = 7.0174362438161719E-001
$-----------------------------------------------------CUBIC_STIFFNESS_FX
[CUBIC_STIFFNESS_FX]
OF = 0.0000000000000000E+000
O = 0.0000000000000000E+000
OS = 1.1030899999999999E+003
Rp = 2.2000000000000002E+000
Rn = -1.0500000000000000E+000
Ep = 4.4000000000000004E+000
En = -2.1000000000000001E+000
RnF = -1.4044600000000000E+003
RpF = 2.1183200000000002E+003
EnS = 2.0600000000000000E+004
EpS = 2.0600000000000000E+004
$--------------------------------------------------CONSTANT_STIFFNESS_FX
[CONSTANT_STIFFNESS_FX]
k = 1.1030899999999999E+003
$----------------------------------------------------CONSTANT_DAMPING_FX
[CONSTANT_DAMPING_FX]
c = 1.1030000000000000E+000
$--------------------------------------------------CONSTANT_STIFFNESS_FY
[CONSTANT_STIFFNESS_FY]
k = 1.0000000000000000E+003
$----------------------------------------------------CONSTANT_DAMPING_FY
[CONSTANT_DAMPING_FY]
c = 1.0000000000000000E+000
$--------------------------------------------------CONSTANT_STIFFNESS_FZ
[CONSTANT_STIFFNESS_FZ]
$----------------------------------------------------CONSTANT_DAMPING_FZ
[CONSTANT_DAMPING_FZ]
$--------------------------------------------------CONSTANT_STIFFNESS_TX
[CONSTANT_STIFFNESS_TX]
k = 8.0000000000000000E+002
$----------------------------------------------------CONSTANT_DAMPING_TX
[CONSTANT_DAMPING_TX]
c = 8.0000000000000000E+000
$--------------------------------------------------CONSTANT_STIFFNESS_TY
[CONSTANT_STIFFNESS_TY]
$----------------------------------------------------CONSTANT_DAMPING_TY
[CONSTANT_DAMPING_TY]
$--------------------------------------------------CONSTANT_STIFFNESS_TZ
[CONSTANT_STIFFNESS_TZ]
$----------------------------------------------------CONSTANT_DAMPING_TZ
[CONSTANT_DAMPING_TZ]
[FIT_REPORT]
FIT_REPORT_NAME = 'sample_gbs.pdf'
Subroutine Definition
GSE Subroutine
- Input Parameters
- The Freq Bushing subroutine is defined in the
AltairBushingMotionSolve.dll (.so) with
GSESUB_BW function name.
GSE subroutine input user string:
usrsub_param_str="USER(P1,P2,P3,P4,P5,P6,P7)"Parameter Description P1Freq Bushing property file name solver string ID (.gbs) P2Preload array ID P3Offset array ID P4Displacement scale array ID P5Force scale array ID P6Unused P7Mount Limits array ID - CSE Definition Block in the xml
<Control_StateEqn id = "303001" type = "USERSUB" num_state = "24" num_output = "6" u_solver_array_id = "30300300" x_solver_array_id = "30300100" y_solver_array_id = "30300200" usrsub_param_string = "USER(303001,30300400,30300500,30300600,30300700,0,-30301300)" usrsub_dll_name = "AltairBushingMotionSolve" usrsub_fnc_name = "GSESUB_BW" usrsub_der1_name = "GSEXX_BW" usrsub_der2_name = "GSEXU_BW" usrsub_der3_name = "GSEYX_BW" usrsub_der4_name = "GSEYU_BW" is_static_hold = "FALSE" />
Mount Subroutine
- Input Parameters
- The Freq Bushing Mount subroutine is defined in the
GSESUB_MOUNT function name.
usrsub_param_str="USER(P1,P2)"Parameter Description P1Stiffness coefficients array ID P2Damping coefficients array ID - CSE Definition Block in the xml
<Control_StateEqn id = "303002" type = "USERSUB" num_state = "6" num_output = "12" u_solver_array_id = "30301200" x_solver_array_id = "30301000" y_solver_array_id = "30301100" usrsub_param_string = "USER(30300800,30300900)" usrsub_dll_name = "AltairBushingMotionSolve" usrsub_fnc_name = "GSESUB_MOUNT" usrsub_der1_name = "GSEXX_MOUNT" usrsub_der2_name = "GSEXU_MOUNT" usrsub_der3_name = "GSEYX_MOUNT" usrsub_der4_name = "GSEYU_MOUNT" is_static_hold = "FALSE" />
Friction Subroutine
- Input Parameters
- The Freq Bushing Friction subroutine is defined in the
Gsesub_Friction function name.
usrsub_param_str="USER(P1)"Parameter Description P1Friction parameters array ID <Control_StateEqn id = "303003" type = "USERSUB" num_state = "2" num_output = "3" u_solver_array_id = "30302200" x_solver_array_id = "30302000" y_solver_array_id = "30302100" usrsub_param_string = "USER(-30302300)" usrsub_dll_name = "AltairBushingMotionSolve" usrsub_fnc_name = "Gsesub_Friction" usrsub_der1_name = "Gsexx_Friction" usrsub_der2_name = "Gsexu_Friction" usrsub_der3_name = "Gseyx_Friction" usrsub_der4_name = "Gseyu_Friction" is_static_hold = "FALSE" />
