Output Requests
The powertrain has a set of output requests which gives information about the states and the outputs of the powertrain with time. They can be accessed by the Request Subroutine POWERTRAIN_REQ with the parameter value of 1, 2, or 3.
Throttle requests
Parameter value = 1
Component | Name | Description |
X | Modulated Throttle | The throttle that is applied to the engine after the modulation from the anti-stall system and rev limiter. |
Y | Input Throttle | The original throttle signal that is applied to the model. |
Z | *Reserved* | For future use. |
RX | Throttle mod indicator | If the signal value is 1 then the rev-limiter is cutting the throttle, if it is -1 then the anti-stall system is modulating the throttle, 0 otherwise. |
Clutch Requests
Parameter value = 2
X | Clutch Slip | The clutch slip state. |
Y | Clutch Slip rate | The derivative of the clutch slip state. |
Z | Clutch Torque | The final clutch torque seen at the other end of the powertrain. |
Engine Requests
Parameter value = 3
X | Engine Speed | The engine speed state. |
Y | Engine RPM | The engine speed state in RPM. |
Z | Engine Torque | The torque produced by the engine. |
RX | Engine Speed Derivative | The derivative of the engine speed state. |
