RADIOSS Contact Parameters
Following method of contact can be defined.
- Face-Face
- Slave Nodes
- Self Impact
- General (supported withType24)
Contact Type: Following contact types are
supported.
- Friction (Type24)
- Tie (Type2)
- Friction + Heat Transfer (Type7)
- Friction (Type25)
Default contact parameters can be modified in the setting “Solver Settings” dialog.
Multiple body pairs: This option allows to select multiple body pairs to define contact. This option is listed only in the manual contact definition.
