Ansys Contact Parameters
TARGE170 and CONTA173 / CONTA174 element KeyOpts can be specified by using the Target_Element_Keyopts options and Contact_Element_Keyopts options.
Various real constants of the contact elements can be specified using the options available under Real Constants group.
If surface names are defined for contact surfaces in SimLab, then the contact elements will be grouped as sets(CMBLOCK) with the surface names.
