ADVC(ADVENTURECluster) Contact Parameters
- Contact Type: Used to select the contact slip property either as Small Sliding / Finite Sliding / Tying.
- Adjust: Used to specify the adjust value which defines the distance by which slave nodes will be moved on to the master surface.
- Adjust To Clearance: Used for avoiding contact elements collapse when moving their nodes using the adjust value.
- Adjust To Interference: Used for avoiding contact elements collapse when moving their nodes using the interference value. It is applicable only for "Finite Sliding" contact type.
- Auto Shrink: Used to control the penetration of contact surfaces when interference is defined.
- Thickness: Used to correct the amount of gap between contact surfaces by taking shell element and membrane element thickness into consideration.
- Initial State: Used to define the initial contact state. Auto/Open/Close contact states can be defined.
- Initial State Tolerance: Used to define the tolerance which helps in automatic determination of the initial contact state.
- Estimate Impact Time: Used to output the Impact/Collision time in a dynamic analysis.
- Search Gap: Used to specify the search distance for the contact surface in the normal direction.
- Search Depth: Used to specify the search distance for the contact surface in the normal direction.
- Search Width: Used to specify the search range in the in-plane direction of the contact surface.
- Search Angle: Used to specify the angle between outbound normal vector of a master surface and inbound normal vector of a slave surface.
- Clearance: Used to specify the clearance between the master and slave surfaces. A positive value represents the clearance whereas a negative value represents penetration.
- Interference: Used to specify the interference between the master and slave surfaces. A positive value indicates that the master surface moved for the given value in the normal direction into the slave surface.
- Penalty Scale Factor: Penalty factor is given by multiplying stiffness of a region connected with contact constraint by penalty scale factor.
- Critical Penetration: Used to control the convergence calculation if the peak value of the penetration exceeds the given value. The convergence calculation is re-started with smaller increment value.
