Nastran Contact Parameters
Contact Type: Nastran contact method can be selected using
this option.
- Glue NX-Nastran
- Contact Pair NX-Nastran
- Contact Body MSC Nastran
- Glue NX-Nastran: Glue contact can be defined using
this option. This type is supported only in NX-Nastran solver. Following
cards are exported when Glue type is defined
- BCRPARA
- BSURFS
- BGSET
- BGPARM
- Contact Pair NX-Nastran: Contact pair definition for
NX-Nastran solver can be defined using this option. Minimum and Maximum
search distance can be specified. Following cards are exported when
NX-Nastran Contact Pair type is defined
- BCSET
- BCTADD
- BCTSET
- BSURFS
- Contact Body MSC Nastran: Contact body definition for
MSC-Nastran Implicit Non Linear analysis can be defined using this option.
Surface behaviour can be Deform or Rigid. Following cards are exported when
Contact Body type is defined
- BCBODY
- BCTABLE
- BSURF
- BCONTACT
