Format and Execute Options
Analysis > Options > Solution Settings > Format and Execute Options
The Format and Execute Options allow the user to set the options which will be taken by Flux PEEC solver (in batch) to solve the current solution.
  • Mesh options (not used for the moment)
  • Execute Solver Options
    The Execute Solver Options define the options used at Flux PEEC solver execution:
    • Number of Processors used to parallelize the solving process.
    • Numerical memory in MB used by Flux PEEC solver. It is defined statically by a memory amount set in MB.
