Battery Module
This tool is used to create an array of battery cells using cell templates 18650 and 21700. The cells can be created either in rectangular or staggered patterns. Default materials and thickness properties (for sheet bodies) will be auto assigned to the respective components.
Cell type
There are two types of cell templates available.
- Cell 18650
- Cell 21700
Cell distance (CD)
It is the distance between two adjacent cells.
Layout
There are two types of layouts available.
- Rectangular
- Staggered
Number of Cells
X-direction: Specify the number of cells in x-direction.
Y-direction: Specify the number of cells in y-direction.
Rectangular
Staggered
Create bus bar
Automatic bus bar creation is supported for rectangular cell layout. Cells in rows and columns are connected in series and parallel respectively.
