/INIBRI/EPSP
Block Format Keyword Describes the initial state for a brick.
/INIBRI/EPSP/unit_ID | |||||||||
brick_ID | value |
Definition
unit_ID | Unit identifier (Integer, maximum 10 digits) |
brick_ID | Element
identifier (Integer) |
value | Date
value (Real) |
- /MAT/LAW38 (VISC_TAB) is not compatible with /INIBRI/EPSP.
- The initial state for brick may be defined by more than one block.
