/INIBRI/STRA_F
Block Format Keyword Describes the initial state for a brick.
| /INIBRI/STRA_F/unit_ID | |||||||||
| brick_ID | Nb_integr | Isolnod | Isolid | nptr | npts | nptt | nlay | ||
For each integration point (Nb_integr > 0)
| 1 | 2 | 3 | |||||||
| 12 | 23 | 31 | |||||||
Definition
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| brick_ID | Element
identifier. (Integer) |
| Nb_integr | Number of integration
points. Corresponds to the property definition of this element. (Integer) |
| Isolnod | Number of nodes of solid
| Isolid | Solid element
formulation. Corresponds to the solid element formulation in property definition of this element. (Integer) |
| nptr | Number of integration
points in direction r. (Integer) |
| npts | Number of integration
points in direction s. (Integer) |
| nptt | Number of integration
points in direction t. (Integer) |
| nlay | Number of layers for thick
shell elements. (Integer) |
| 1 | Strain in direction
1. (Real) |
| 2 | Strain in direction
2. (Real |
| 3 | Strain in direction
3. (Real |
| 12 | Strain in direction
12. (Real |
| 23 | Strain in direction
23. (Real |
| 31 | Strain in direction
31. (Real |
- The initial state for brick may be defined by more than one block.
